1985 GL1200I. I took the front wheel off to replace the seals in the forks. After completing that I started to re-install the front wheel. When I was lining up the wheel, this piece (shown in picture) fell off. I have no idea where this goes. I looked and looked and looked!
Can someone please tell me where this goes? Don't know if it is important or not!
Thank you
Bill
Pull the caliper off ( it will probably be the second one you remove ;) ) . Remove the brake pads and you will see one end of the caliper has holes drilled for the two little pegs on that shim to fit in place.
