1 - 15 of 15 Posts
Ebay has them, online stores have them, all are either a lot of money or the shipping is crazy.
This Honda 16900-371-004 FILTER, FUEL is also used on these models and components: why don't the parts stores getting in on this ?
1976 GL1000
1976 GL1000LTD
1977 GL1000
1978 GL1000
1979 GL1000
1980 GL1100
1980 GL1100I
1981 GL1100
1981 GL1100I
1982 GL1100
1982 GL1100A
1982 GL1100I
1982 VF750C
1983 GL1100
1983 GL1100A
1983 GL1100I
1983 VF1100C
1983 VF750C
1983 VF750F
1983 VT750C
1984 GL1200
1984 GL1200
1984 GL1200A
1984 GL1200I
1984 GL1200I
1984 VF1000F
1984 VF1000F
1984 VF1100C
1984 VF1100C
1984 VF1100S
1984 VF1100S
1984 VF500C
1984 VF500C
1984 VF500F
1984 VF500F
1984 VF700C
1984 VF700C
1984 VF700F
1984 VF700F
1984 VF750F
1984 VF750F
1984 VT700C
1984 VT700C
1985 GL1200A
1985 GL1200A
1985 GL1200I
1985 VF1100C
1985 VF1100C
1985 VF1100S
1985 VF1100S
1985 VF500C
1985 VF500F
1985 VF500F
1985 VF700C
1985 VF700C
1985 VF700F
1985 VF700F
1985 VT700C
1985 VT700C
1986 GL1200A
1986 GL1200I
1986 VF1100C
1986 VF700C
1986 CN250
1987 CN250
1989 CH250
1990 CH250
1992 CN250
1993 CN250
1994 CN250
1995 CN250
1996 CN250
1997 CN250
1998 CN250
1999 CN250
2000 CN250
2001 CN250
2001 NSS250
2001 NSS250A
2002 NSS250
2002 NSS250A
2003 NSS250
2003 NSS250A
2004 CN250
2004 NSS250
2004 NSS250A
2004 NSS250AS
2004 NSS250S
2005 CN250
2005 NSS250
2005 NSS250A
2005 NSS250AS
2005 NSS250S
2005 PS250
2006 CN250
2006 NSS250
2006 NSS250A
2006 NSS250AS
2006 NSS250S
2006 PS250
2007 CN250
2007 NSS250
2007 NSS250A
2007 NSS250AS
2007 NSS250S
You may be able to tell that I'm not much into stock. I got mine at NAPA.
Cyclemax of ohio has them and the dealers ofcorse. and both are a little pricey but alot of the parts store filters come apart internaly after a while then you have a diffrent problem called pull the carbs and clean.
Its worth the price to me to get oem once every couple years.
CycleMax Ohio had a deal a while back which included: 4 spark plugs, oil, air, and fuel filter for 25 bucks. didn't sound too expensive, i bought 2.
Wild Rhino - Canadian
I got an OEM filter at the local Dealer and is set me back about $14.00, sure it cost me twice what the other option was. The Dealer even wanted to sell me the cheap one. The OEM filter goes back in place and bolts down like it is supposed to. No Ozark engineering on a critical item for my wing. (read that to mean no bailing wire, chewing gum, or half assed fixes)
1987 GL1200 Interstate
I just paid nearly 60 bucks for 3 filters. Air, oil and fuel. That was OEM from the cheap dealer. However...
The oil filter is changed at 3K intervals. The other two at 20K. Lately that's around two years of riding. For most of you 20K miles would be 5 years if you're lucky, so why scrimp? It may be the only time you actually replace them.
02 GL1800 w/Auto Pilot
The fuel filter? I just get a see thru inline filter from the auto parts store. Cheap, and it does the job.
Autoparts stores (like Napa) for around $2.00 to $5.00.
Try a NAPA 3011 fuel filter. It's a see-thru filter that fits the OEM clamp quite nicely.
EMGO filters had (have?) issues with coming apart internally after only a few weeks. I'm not sure if they have resolved that issue or not.
Discussion Starter #12
I have napa in now but they are too tight, I am afraid they might split out. I have some I got from Cresent moon cycles finally. they are just right, but I am not sure if you will ever be able to get them from them again.
i'm with the croud thst uses an oversized 'for goldwings" auto filter. they are clear and made by fram not shure of the # off the top of the head.
i can only find them at agro stores for somee reason. they are about 2" dia and are clear. i mount them on a 2 inch line running to the fuel pump. they are not mounted in stock location over the hot engine, you can also look down and see easily how much fuel is in the filter and any crap that may be in there. it does not look stock but if you did not know goldwings it look's like thats where the factory may have put it
wilf
Gregarious Greeter
As much as you post in the tech section I am suprised to see that you actually ride 20,000 miles a year on your wing:shock:
Of, course in AZ you probably get to ride year round.
I have never put20K on the bike in one year. And with the on-going carb problems, my riding time is very diminished lately. However, I did manage to put 23K on the last filtersince installing it in April of 2009.
My point was, as seldom as you change the filter, why not splurge and get the good one.
1 - 15 of 15 Posts
