1 - 12 of 12 Posts
Can anyone tell me which front brake disc is controlled with the right hand lever on a 1500? I have a noise which appears to go away with application of the hand brake...............
Cheers!
T.
Discussion Starter #2
Please disregard.................didn't get an answer in the customary 30 seconds so got off my behind and rummaged thru my service manual.
Front right...............
Now, off to see if my pads are draggin'
:weightlifter:T.
Right front on the 1500. Check the pads. Have the pins been cleaned and lubed? Piston clean of pits and rust?
30 seconds!!!!!????? Think this is McD's?????
It takes 30 seconds for the forum to catch up and post after send now hit.
I hate to confess that I was in McD's today.............took a LOT longer than 30 seconds - go figure. And just why does the drive thru get theirs faster than the guy at the counter?
In any case, I also confess that I was pokin' fun, you guys, and should have made the effort to look it up in the first place. And that the "thirty seconds" was a figure of speech - it was actually more like five minutes. :ROFL: Have seen this site give an answer or suggestion in half that time.
Haven't looked yet, but suspect that my front caliper isn't sliding on the bolts freely, which is what was happening on my rear brake in the fall last year. Rear bolts turned out to be corroded and had to be replaced.
Have I stirred it up enough now?
T.
Well....YUP.......keep diggin'..!!
Cheers,
Peter.
Ya know, I have come to that same conclusion myself.
Now I always take the driver through, even when it seems to have 5 cars in front of me.
Anti-Guru
Cheers!
T.
:wtf: Just spin the wheel, press the brake lever, and see which side of the wheel stops first !!:D
Senior Smart Aleck
satan wrote:
Cheers!
T.
LMFAO!!! Thanks Satan. I needed that. :claps::claps:
BTW- Which side shoulkd stop first? I'm gonna go check mine now!!
Discussion Starter #11
Just when I thought I had it figured out some wag (obviously a term of endearment!) has to introduce a new element to consider........................:cool:
Will it matter if I'm spinning the wheel backward?
T.
Hello from the Orkney Isles!
As the others say, Right Front on 1500. On any linked system with flexible hoses it's easy to find out without trying to see which side stops first (there's hardly any difference anyway :cool:) If you grab the long flexy down to the caliper and put a small curve in it with your fingers and then squeeze the lever, you will feel the hydraulic pressure try to straighten the curve. On the wrong side flexy, you will feel nothing.
1 - 12 of 12 Posts
