Which Switch is Which?
791 Views 7 Replies 3 Participants Last post by  Mohawk
Howdy,
My Wing just today developed a problem when starting.
Occasionally when I push the starter button I get nothing.
When I try a few times I will get a click when I release the button.
If I continue to try it will start like normal.
I first thought it was a low battery or bad connection.
So I rode home and took it all apart and cleaned every connection I could get at while I had the battery charging.
The battery seemed to be up, but I topped off the cells and charged it anyway.
After I was done I put it back together and the problem still persists, So I took ot apart again and discovered the TWO Switches or solenoids that click.
I have identified the one that is mounted to the front of the Battery box as.
Item # 13 35851-MN5-751 SWITCH COMP. or it's also listed as
Item # 12 35850-MT8-671 SWITCH ASSY. COMPLETE
Now these numbers came from my CDMOTO parts PDF. and they are different from the one that Tallyho is using.
The other switch I need identified is mounted on the frame rail same side and right behind my Oil Fill spot.
It might be this one...
Item # 11 35850-MT8-000 SWITCH ASSY. IF THIS IS FORWARD OF BATTERY ON FRAME RAIL
Let me know what you think.
Thanks in advance
Mohawk
hi mohawk your ok on the switches your looking at but have you cleaned the starter button with wd40 ect they are knowen to stick with dirt ect
That's my next project.
I do find it hard to believe that it would start so well one day and then go all different the next day.
But I am going out and do that now as the searches I find point to the same.
stranger things have happened i never use the words it cant be that it dont make sence
I'm attaching a graphic to show Tallyho the two switches.
Hey, After a few hours of Taking everything apart and cleaning every contact I could get to. ( I Even removed the battery box and got the ones behind there )
I even took the starter switch housing off the bike but didn't want to screw with the throttle cables.
So I did a search and from Anogels suggestion too, I sprayed my Starter switch with contact cleaner.
It worked Great.
Go Figure, a 10 second fix. worked better than 4 hours of real work.
I hit the kill switch and the starter button worked perfect 10 times in a row.
So Now I'm off to spray all my switches.
PS, Make sure you cover all your Tupperware when spraying anything top side.
Thanks All.
I'm a button pushing now.
Mohawk
I am T/S the same problem after a 300 mile ride yesterday. This morning nothing, no clicks or anything also notice the neutral light is not working either. During my ride yesterday I noticed the OD light was out, is that a hint???
I would check the dogbone fuse located forward of your battery.
If you have nothing at all, It's something major like that.
Good Luck to you.
Mohawk
