1 - 16 of 16 Posts
I am hopeing to be able to order a trike kit for an 1800 and I would like to hear all the pros and cons for the different models and is there one that actually allows some lean to it
Just one of the guys
I have the Triwing kit, got it because I could afford it and I have the Skilled help (Brother) to help me put it together. They don't make one for the 1800 so they will be of no help to you.
I have never heard of one that allows lean.
So how hard and involved is it to install one of those?
I'm not sure what you are asking. I had an '87 1200 that was triked out. I liked it very much but I wanted to get back to just two wheels under me.(personal enjoyment) I also bought a '03 1800 that had a voyager kit(take on or off in short time trike kit) I didn't really like it at all and it was done professionally, whatever that means.
Trike Master
I'll keep this as short as possible.
1. If you want to install your own, your choices will be very limited.
2. IRS gives a smoother ride than straight axle models
3. Extended wheel base IRS models give an even smoother ride
4. Rake kits for the steering are a must. The degree needed depends on the model conversion you pick.
All models have their pluses and minuses. You should test ride as many as you can and make your choice.
If you intend to have it installed, the installer you pick is as important as the kit you pick!
If you intend to add the foot boards/foot fairings(various other names) be aware for some maintenance items, they must be loosened and or removed. No problems for oil/filers change but, anything that requires the removal of the lower cowl will mean the foot fairings will need loosened or removed.
If you desire to check the LoneStarTrike forum, you will find a wealth of trike knowledge there you can learn from.
I am the Hobo
Chris has a CSC Cobra on a 2003 1800. We've had it since 2005 and she has done about 35000 miles on it in UK, Ireland, France, Belgium, Holland and Luxembourg. Its just brilliant and customer service from CSC is second to none. It rides well, handles well, tows well, looks well and simply ticks all the boxes.
We are thinking about upgrading to the Viper on the 2012 model.
thank you for the reply's the reason this question is coming up is if you remember 3 yrs ago the wife and I went down at 70 mph I have been riding but the wife will not she said she might be interested if I get a trike so I am looking at possibley new with professional install or used but I just want to know if there is any ones I should steer away from and what options to have to make it more appealing to my wife I really miss my riding partner and would love to have her back there again
thank you again
nightwing83
Ok, now I understand, my '87 was done by Motor Trike, and was put on in the 90's. It was fun riding and tripping. As I understand, Hannigan is one of the better trike kits. I've talked to a number of people and that's the one I would choose. As deputydawg says, making sure the person that is putting it together is knowledgeable and has the experince is as important as the kit. Have you ever thought about a side car? More storage, more room for partner, and you still can ride two up, if you want. Another note: with a side car, you can take it off/put it on, if you want to ride with two wheels.
Discussion Starter #10
i would not mind a side car but she said flat no I think her being able to see something on both sides of her is comforting to her she still has not recovered from the brain injury and as it looks never will but anything to give her peace of mind may help her get back in the saddle again I had even looked into a can am spyder but again she wanted more on each side of her like the standard trike kit
Nightwing83. you hit the nail on the head.its what is most important that you have your rideing partner back and she is able to free her mind and enjoy it.. i work for none of these companys nor have i ever. but my personal experience. test riding them would be either CSC or Hannigan bar none.
They both are the most comfortable and best handeling out there.
Best of luck and my prayers for you both.
I went with ROADSMITH, main reason was it's 8" longer than other brands. The longer wheelbase will give a softer ride. I'll agree with the other post get your co-pilot armrest.
Had trike for 2 years. Miss the freedom of two but a lot of versatility with the trike.
TWO BIG PLUSes: SAFETY The extra width seems to make the trike more visible to other drivers entering the road. Constantly seeing folks starting to pull out and then stopping, having seen the trike. My two wheeler experience would have figured those same folks for continuing to pull out.
Second, my wife with hip problems can mount easier with the trike than the two wheeler queen seat.
In retrospect, I would like to have a parking brake. I understand one of the kits has a parking brake, believe it was Champion.
Trike Master
Could you please explain your comment: "wife with hip problems can mount easier with the trike than the two wheeler queen seat."
1. Do you have a Wing trike?
2. Do you have a different seat than OEM?
3. Have does the trike make it easier for you wife to get on?
My wife mounts by using the passenger foot rest and swings her other leg through as she always did when we were on 2 wheels.
There are several conversions that offer parking brakes.
What conversion do you have?
Got a GL1800 with Road Smith conversion. Prior bikes have been HD not GW so no center stand which explains why it was hard for her to mount. She basically has to stand on mounts, then sit side saddle and work back into the seat with her legs and hips until she can swing her leg across.
In fact, didn't know GW came with center stand until I was under the trike one day and "GeZammm" there it was still there!!!
Trike Master
Thanks for the explanation.
My wife suffered a stroke a few years ago and had to mount by getting on my seat-sliding back to hers and then I had to lift her leg over for her. This was on a HD Ultra, which has no center stand!
With rehab, she can now mount our Wing/Hannigan as she use to- uses her foot rest and swings her leg through.
Doesn't matter how one has to get on-Just get on and go:claps:
1 - 16 of 16 Posts
