Hi There,
I have 93' aspencade with 44k miles on it. When I start her up, I put the choke to 2000 rpms for a minute or so then let it return to idle around 800 - 750 RMPS. It emits white smoke during this process and I am wondering the route cause or if this is a concern I should address. She seems to run fine regardless.
I need to determine if this goes away after running for a a while after she warmed up.
Thanks for your help!
Gwanger.
Some will smoke if you keep the bike on the sidestand for any length of time. If the smoking stops after a few trips around the block, you should be fine. I put mine up on the center stand and that stopped the morning smoke on mine.
As mentioned, if it's only coming out of the left side then you're probably ok. Oil will seep past the rings especially if it's been sitting for a few days.
