1 - 3 of 3 Posts
there is neutral stop lever with steel wheel, which has to hold drum in neutral position.
I think most likely just spring has to be replaced. And 5-6 gasket/rings to install front cover.
this little spring also pulls gear stop lever. Kind of triangle, 2 levers and spring pulling them to each other.
That spring broken or disconnected wouldn't necessarily make it hard to find neutral but it would want to fall into gear by itself.
1 - 3 of 3 Posts
