Timing belts were changed just 5000 miles/3years agoSounds like you found the problem, if you havent changed the timing belts it might be an idea to do that as well as i think i had to remove a tensioner to get the pulser coils out, Gates T275 i believe
Kind of impressive if you think that 1 volt signal is amplified to 12 volts by the ECM. Then up to 10,000 volts by the coils.👏👏👏👏👏,simple fix,RIGHT,
No it will not.If the BAS is bad ,will the starter still turn the motor over?
