Been working out of state. Wing has been in garage for about a year. Want to get it back on the road. Anything special I should do?
Did you try and start and did it start? If so you got some good advice from the other posters.
If you did not put Sea Foam or another type of fuel stabilizer in the tank to start with, drain out all the old gas first. Start with fresh gas with Sea Foam in it to clean out the fuel system. Dump the old gas in your vehicle. It will mix with the fresh stuff.
If you did stabilize the gas before you stored it, charge the battery, change the oil, air up the tires, fire it up and ride it
