Hi everyone,
I'm new to this board so "Hello" to everyone out there. I've got a 1983 Goldwing Interstate that has seen some moderate neglect from the previous owner. I've had it for a few years now and it's pretty well in order. Now, I have a problem I'm trying to figure out.
When I went to ride it back in December, it cranked momentarily then died completely. No lights oranything. I suspected the problemwas the burned-in-the-past wire connector that goes to the starter solenoid. After rewiring those 4 wires to make proper contact, the motorcycle lights came on with the key and it cranked like it was going to start. I ran the battery down trying to start the engine. I recharged the battery overnight and tried again next morning. No luck. It just cranks but does not start.
I tried pulling a spark plug and grounding it against the case and cranking. It had a good spark. I checked the air cleaner and tried cranking with it removed with no luck. I checked the fuel pump and it pumped fuel. I replaced the fuel line from the tank to the pump and the fuel filter. No luck. Next, I pulled off a spark plug and inserted a rolled up papertowel into the cylinder and cranked. It came out dry. So, I pulled off the air intake and cranked using full choke and no choke. Even though there's fuel in the tank and in the lines, there was no fuel coming out of the carb into the intake.
It sounds like I've got everything I need but fuel to the cylinders. Any idea what that would indicate with the carb? Stuck float? Clogged jets? Is there a way to clean the carb out and get it working short of removing it from the bike and disassembling it? Or is there another diagnosis? Any help would be appreciated. Thanks
pac13man
Hi everyone,
pac13man
