You also have to change the air in the tires to winter air. Just don't forget to change it again come spring.1) you must reverse the Battery so that the bike will produce heat, not Air Conditioning.
2) you must grease the Muffler Bearings, or they will rot and fall off
Only if it "Smokes" over the winter....!!Will it need CPR next spring
Funny MikeOnly if it "Smokes" over the winter....!!
Dale you have missread, a lift in the UK is what you call an elevator so you should have been using hydraulics or a winch!
