if you need carb parts... http://www.randakks.com is the place.. for the float valves only at the dealer. jets can be reused, carbs are no big deal, well it may look very complicated, but once you have them on the bench, its easy cake. just do one by one and use the others as reference in case you dont remember where things go.
about the front end noise. give a better description. will it go away if you gently push the brakes? if its only while driving its wheel related, if it happens at idle, then its the engine.
