Hi
I was told that for the winter I should fill fuel tank and add 1/4 bottle of ATF then run bike so that mixture would get through system. I am told this will prevent injectors from fouling and coat cylinder, instead od removing spark plugs and adding oil directly into cylinders.
Has anyone ever used ATF in there fuel ?
Any help I could get would be great.
Thx
Al
Old School Guru
Put in 6 or 7 oz of Seafoam to a full tank of gas and run for 5 to 10 minutes. That should be good enough. ATF could actually block the injector ports after a long winter. Plus, it could hurt the cat converters. I wouldn't use it. I'm fortunate here that I ride year round, so my bikes never get stored for the winter. :smiler:
Gene:action:
Ditto on the Seafoam or even Marvel Mystery Oil (MMO). I would think the ATF would leave a coating on the parts, I wouldn't use it.
