I'm running it on my 01 yamaha road star, minimal modification required actually. Shortened ~1.25" and grommets in the other end with spacers and it bolts in, the pump under the right side cover. Someone else figured out how to do that, but no one has figured out the meter part, and as a former electrical engineer, I figured I'd give it a stab. If it's resistance I can program an IC to do math then output to an LCD screen a numeric value between 0-25. Same with voltage. It's easier to find a lcd volt meter than ohm meter, but either way I'm going to make it look nice.
My load varies greatly from 950lbs to 1300lbs from solo to 2-up with weekend gear, so adjustable is great. My up/down switch is on my left side panel. Right now I can only adjust when the bike is off because I have to go by the sound of the motor and wait for it to bottom out.
I completely drained the preload and filled it with fresh fluid, worked all the air out, and have full 0-25 capabilities. I actually get about 1.5" of height difference between the two absolutes.
This is the only picture where you can actually see the shock, as I'm making adjustments.
Had to do some creative maneuvering to get the pump in
Here's my switch, drilled through the cover and mounted it up. Used two relays, it worked very well
