Hi all,
I've read a few threads regarding similar problem and tried wiring the ground direct at the rear connector for the taillights to no avail.
Just bought this bike 6 mos ago and have put app. 4k miles on, noticed when sitting holding the brake lever the engine would decrease rpm then let off the brake lever and rpms go up ever so little. Figured there most be a wiring problem somehow and would need to look into that. Today however a major problem flared up. When using a turn signal, either direction the fronts work but the back ones don't. The two indicators on the dash are both blinking as if the emergencies are on, in the rear lights appear to be going off all over. When I set the emergency hazard button they appear to work fine it's just the rear turn signals. I'm about try looking at the bulbs in the rear but can't imagine a bulb is out since I see them on with the hazards on. Any ideas would be appreciated. Thanks much
