hey guys. Here I am again wiring my radio. I looked at the manual and I have the correct wire colors but it does not say what each wire is. I have
blue/black
red/blue
yellow/red
white/blue
By my count I should only have 3 direct power
acc power
ground
what am I missing besides the speaker wires . Maybe auto volume?
Are those wires on the radio or the bike harness? Looking at the wiring diagram those colors,except the white/blue match the mute and search switch. there is a yellow/blue on the diagram.
The scematic shows another 4 pin plug with Green, Brown/White, Red and Light Green/Black
Lg/Bl comes from the 20 amp fuse in the left pocket I think that is the main power.
I think the Brown/white goes to the dash
Red I think is the memory function powered from the 7.5 amp fuse, this is live all the time.
Green I would assume is the ground.
The same wires goes to the clock except for the brown/white
If your radio has a memory function use the red wire.
Thanks guys . the radio is wired in.
Red is constant power
green is ground
Geen with blue line is ignition power
Brown has no current at all, May be auto volume.
Just wired my 3 in. Good MONEY
