I’m have a 2004 Honda goldwing new alternator and rectifier and still won’t charge I’m at my ends wits don’t know where to go from here place I need help someone help
Exactly. Disconnect the green plug on the back of the alternator. With a volt meter check the black/yellow wire, it should show battery voltage, then the black wire, start the engine and after 8 to 10 seconds it should show approx 5 volts.I will defer to someone that really knows, but I am pretty sure that the alternator needs a signal from the ECM before it will start the charging process.
Yes it does the black and yellow shows 12.3 volts then with the plug unplug the black wire show .5 with the motor runningExactly. Disconnect the green plug on the back of the alternator. With a volt meter check the black/yellow wire, it should show battery voltage, then the black wire, start the engine and after 8 to 10 seconds it should show approx 5 volts.
Don't know what you mean by "replaced the rectifier", it is built into the alternator.
First, lets clear something up...It was 5 volts could someone tell me it the regulator/rectifier relay box have anything to do with this changing problem
What are you talking about? It doesn't have anything to do with the charging system whatever it is but would like to know what you are referring to.It was 5 volts could someone tell me it the regulator/rectifier relay box have anything to do with this changing problem
mine is a 2002 and it has the delay, they all doDoes the E.C.M. control when alternator kicks in on ALL 1800s? I was led to believe this might have been added to latter years 1800s to make it easier on the alternator drive gear on start up.
gumbyred
The 2017 as well.mine is a 2002 and it has the delay, they all do
Maybe, that's why I asked the question can he tell if the alternator is turning.Did I swerve into the answer? Failed alternator drive gear?
gumbyred
yes alternator is turning like I said the volts is get back to the reverse regulator but it’s not going from there to the batteryMaybe, that's why I asked the question can he tell if the alternator is turning.
I'll try also.Ok now if I test the voltage coming out of the battery with the bike running then the voltage keeps going down but if I test the voltage coming out of the reverse regulator then it is going up where it is suppose to so where do I go from here
