1 - 3 of 3 Posts
Key in accessory position have display, turn to on and display goes blank, will not turn over. Neutral light is on. Meter shows 12 volts at battery.
check the ignition fuse, make sure the batt contacts are clean. try putting the volt meter on the batt when you turn the ignition to "on", the batt might not have enough amps to put out when the headlight comes on.
Good call, battery drops to 5.4 with key "on". Thanks!
1 - 3 of 3 Posts
