Here it is.. sure it has been covered here before.. but i missed it... going to do some work on the front end of lucille... 81 1100 interstate... need to replace the speedo drive.. have a new front tire put on.. check the bearings so on... so what i am needing to know.. is how do you raise the front end of your bike when you work on it...... Thanks in advance for your replys....
I usually put it on the center stand and put a small jack under the front of the engine. Jack it up till the bike is tilted back on the back wheel.
Put a thin bit of wood between the jack and the engine, less chance of it slipping or damaging the sump. :waving:
always works for me... of course, with my side car I can lift either end lol
Yes the side car makes it easier. I did the back tire a while back with a fence post and a rock.
What he said, may still need to deflate tire for added clearance... :gunhead:
I always use a tie-down and secure the centerstand forward to the frame to prevent...you know...the accident.
