1 - 9 of 9 Posts
If dyna 3ohms coils were put on, would I still need the ballast resistor? Points are in the bike instead of electro ignition
Of the two, which or would either function with having breaker points still?
Discussion Starter · #2 ·
Follow up: I took the Goldwing over to eastside performance to have it wired up, guys saying the coils are getting too hot and aren't showing spark. I asked him to try and trim the wire down a bit to rid of the frayed ends of the coil wires, he recommends eBay used coils for mounting reasons, I'd prefer something new out of a box however don't exactly have the coin to throw hundreds at a set of oem coils, would the 1100 coils function the same or ballpark enough or would those 3ohm dyna minis function better? If I did either, would I need a new ballast resistor?
Probably should put in a 1 ohm resistor. If your coils are getting hot and not firing the points are probably not opening or a short to ground in the wiring or maybe the condenser is shorted.
I'm not familiar with those coils but they look like single output coils. The 1000 still has the wasted spark. right? Need double output coils???
EDIT: I see now/ The top set has double output.
I've worked on old bikes for many years. With 3 ohms you have lower resistance. These are used with electronic ignitions. Points and condenser use 5 ohm coils. The 3 ohm coils with points will get hot and leave you on the road.
The condenser was brand new, so the top ones labeled for the cb and 1100 would be a better go to for all accounts and purposes, should I get a new ballast resistor also to be safe?
Not really the bikes listed in the top one are all electronic mot points
Hard to say, they don't go bad. Those coils on the top say they are for 1100s 80-93 & 1200s but 80-81 1100s had a resistor and 82 on did not.
Coil information sheet from above coils.
Ignition Coils Caps and Wire For Honda CB650 GL1100/1200
Ignition coils, caps and spark plug wire for the Honda CB650 and GL1100/1200, see fitment list below. This is a great kit if your updating the 30+ year old electrical system!
Kit Contains:
Ignition Coils - Quantity 2
NGK 102 Degree Spark Plug Cap - Quantity 4
Spark Plug Wire - Quantity 8 ft.
Coil Information:
Ohms: 2.5
Coil Length: 80mm (3.1")
Total coil length including wire leads and mounting brackets: 125mm (4.9")
Coil Diameter: 53.5mm (2.1")
Mounting holes are 102mm (4") apart center to center.
Replaces Honda Part Numbers: 30500-422-003, 30500-422-013 - Coils
Replaces Honda Part Number: 30700-MC8-000, 30700-KR3-670 - Caps
1 - 9 of 9 Posts
