WTB,, 78 GL1000
1361 Views 10 Replies 5 Participants Last post by  Mule
Hi I am in need of a Head light bulb and bezel I have a bucket . I believe is a 7" bulb clean chrome on bezel.
Also I need a clean set of Turn Signals with the short stems to mount on the forks of a 78 GL1000 they are the old style round chrome lights and have 1/2 in -13mm threads and a large about 3/4in spline but are short only 2in long , the splines are much bigger than other CB of that year.
If some one also has the long rear tail light mounted stems for the rear turn signals I could use a pair as I just bought some junk ones at the auction and the chrome is non existent.
Don't be offended if my cash situation doesn't meet your need situation on the parts, :dude:
Business is slow...
send PM
Found! Found! Found!
Our local outstanding Member"Broke Winger" pm 'd me had the light and met me half way with the Head light and turns same day I posted done deal Thanks!!!
1 - 11 of 11 Posts
PM sent.
would like to have the info sent for turn signal stems to fit 78 gl1000, if you don't mind. Thanks in advance!
Hi I am not sure I understand what info you need ? The Honda part number for 1978 GL1000 front turn signal mounting bolt is, but is not available from Honda anymore. They are short and thread into the lower end of the fork cover . The rears are the same type but are about 4" long and mount into the holes on the side of the tail light assembly.
90129-431-670
BOLT, FR. TURN SIGNAL MOUNT (Honda Code 0639336
http://maor.pair.com/chopper1/aw2k/LotImg15349.jpg is this what your looking for
Thanks We are getting close.. In those 13m or so holes thread a hollow bolt that has a splined head that the turn signal clamps onto.. Do you have that..
Ok Gang I have found the best picture to date and hope someone can help. here on the picture you will see the holes on the bottom of the headlight mounts or fork covers. that my front turn signals will mount to. Again a short threaded stud about 7/16 or 13mm threaded into the fork cover and a splined 7/8s nipple to clamp the signal to. If you have please PM me.. Thanks Much..
I now have the turn signals and headlight but still need these small mounts.
Yes, I was lloking for a resource to acquire the mounts that are no longer availablethru Honda.Any "heads-up" are appreciated! Thanks...Kyle
Still searching for stems to fit '78 1000 fork-sleeved, headlt./turn signal mounting chrome piece. Any help?
Hey Britman, the web page/link you have posted is no longer up-n-going.
Just a lil FYI!!
1 - 11 of 11 Posts
