Loyal member
A friend just purchased a new to him 90 1500,we would like to install a cb on it.It currently has duel antennas on it so if you have or know anyone who does have a cb radio (other than e-bay)for sale please let me know.We would also need the mounting bracket and sub harness.As always thank you.
If it has dual antennas, did you check if the harness was left on it?
Is it going on an Aspencade, SE or Interstate?
I wonder if a cb off a GL1200 Aspencade would work??
Might have one.
There are different connectors and pin layouts. You might be able to Jerry rig it.:?
parted out an 89 and still have the CB and wiring harnesses. If you're interested, make an offer through the pm system. thanks
Just bought a 1998 SE ( I think it is...how can I check to tell for sure ) and wondering how do I test to make sure the CB is working? It changes channels BUT I'm not picking up anything......
trj827
To Test the CB
First you need a mic or working headset(do not push the talk button with out a mic or known working headset) or you can blow the CB
and then some one with a working CB nearby(more than 100' away is best) that you can talk to and listen to.
I have a CB and Harness that is about to come off my 94 SE. I don't use it, and have something else I want to put in it's spot. Make me a good offer, and I'll remove it tonight.
Ride Safe,
Rich
