1 - 3 of 3 Posts
Am looking for a pair of Broke forks from a 1999/2000yr GL1500.
Need the type that has the Air Cap... which I'm going to swap over to my 1990. I also want to "play" with the remaining portion, to practice rebuilding them prior to doing the real thing on my bike.
A Bent pair would be great... CHEAP please.
You do know the fork internals on the models with air are identical Alex? The only difference is the cap, it has the shrader valve screwed in. You don't need any other parts.
Put the cap in your 1990 and you are good to go for air forks.
Yes, but I want the Entire Fork so that I can work off-line, making the Cap Removal Tool and doing a dry-run on a fork rebuild, prior to doing the "real" ones on my bike.
1 - 3 of 3 Posts
