Can any one tell me what it takes to turn on xm radio on 2010 Goldwing? Thanks jdtkat
Do you have level II or above with the nav screen? If level I, audio-comfort, it doesn't have built in satellite radio. That's what my 2010 is, the base level I, and I have an add on Sirius radio plugged into the AUX cable in the left pocket.
Just one of the guys
If you have a Sirius/XM unit it should work on channel 1. It is an info channel about Sirius/XM But it is a good test to be sure you have the capability and connection necessary to use it. While on Channel 1 it may show your radio serial number or you may need to press a button or two to find it. Contact Sirius/XM with that serial number to get it turned on.
