1. '88 and '89 had an air jet controller, plumbed into the top carb vacuum port, and another (outer) port,my later ('95) carbs don't have. Did you split off from the top port for both controller tubes, or abandon thecontroller (cap the ports) ?
2. My '88 has cruise, but no "cruise control cable" which my manual says cruise control equipped scoots are supposed to have. I just have the push-pull throttle cables, and the choke. Is this normal ?
3. I've got a microswitch mounted to the left carb, that is actuated by tension on the lower throttle cable. It is wired to the plug junction point behind your left knee. This thing isn't mentionedin the manual, and I don't see it on the wiring diagrams. Did you guys have this thing ? Is it for that controller ? Did you keep it ?
Any time, and guessworkyou guys could save me would be greatly appreciated. I'm under some time pressure, anddon't want to go back in here anytime soon. Thanx a bunch.
