I have the Honda CB radio installed on my 2003,GL1800. Sometimes when I'm receiving a message, I hear static. When I'm standing still the reception is clear. When I'm moving there's static on the receiving end. I'm told that my transmition is clear.
The static isn't continuous, it's sporadic. Are there any ideas out there as to what could be the problem?
I removed the grounding plate, inside the trunk, for the antenna. Cleaned up all the contact points for ground. The two holes where the antenna bolts to, and the hole where the plate bolts to the bottom of the trunk. Haven't had the opportunity to test it out as yet. Thinking that there was a possible grounding problem.
Thanks,
Kickstand
Thanks,
Kickstand
