n2xwv wrote:
Hi, so i have no idea and so i ask, why do the guys change fluids, brake fluids and gear oil in final drive of motorcycles, never have done it in a bike or a car? just normal engine oil changes and filter changes,, seeya john n2xwv
John, there are different types of brake fluid.. the Dot 3 & Dot 4 are very good at absorbing water & holding it in suspension.. As a rule that doesn't cause much system harm.. After enough time, (depends on how much moisture in the air, breathing cycles of the brake fluid reservoir, temperature swings), the moisture content in the fluid exceeds what the fluid can isolate & then is when the corrosion damage begins.. A second issue is: as the brake fluid absorbs moisture the brake fluid boiling point lowers so brake fade under hard braking then becomes an issue..
Now the Dot 5 (silicone) based brake fluids have other issues (they are by nature not hygroscopic so don't absorb water) but that isn't a good thing either because anywater (moisture) that enters the brake system quickly settles to the lower parts of the brake system & quickly forms corrosion in those areas..
Depending on the brake system, how good it's sealed from the atmosphere, how long the vehicle sits inactive, the brake fluid should be changed anywherefrom between 1 to 3 years.. My BWM "R" bike with power servoABS brakes REQUIRES the fluid be changed every year.. As a rule I change the brake fluid every other year in my other bikes.. When changing out the brake fluid it is a good idea to pry the brake pads back into their bores & wedge them there during the bleed processas that also allows the old fluid in the piston bores to be bled out with the changed fluid..
Now on the gear oil?.. That is subject to "shearing" do to loading from the hypoid drive gears so does loose viscosity as it it goes through the miles.. Also the anti scuff & anti wear EP (extreme pressure) additives in the gear oil degrade over usage so that is also subject to being changed every few years..
A side issue on motorcycle gear oil is the rear drive units on motorcycles have a fairly exposed vent on them.. That vent is also down low & gets hit with a lot of road spray, dirt, dust, washing high pressure water, so the gear oilon motorcycles tends to end up with water in it after a while (a sure way to pit the bearingsthen trash out a rear drive unit.. Seeing as most motorcycle rear drives only hold a quart or so of oil it is a very good idea to change it at least once a year & if possible twice, (spring & fall)..
Twisty
