I have no knowledge on the trikes but I stumbled on an interesting post on another board. Normally I would post the link but you have to be a member to read or post there. I hope that this isn't an issue as it looks like he is posting to share his findings with others. This was posted by CrystalPistol. Here it is:
[align=left]Progressive # 11-1112 is for Kawasaki KZ1200/1300 (in my 1500 trike)
20.75 " L <>1.19" OD <> 45/70 Lbs/In.<> near 0.210 wire <> 54 winds
Progressive # 11-1122 is for GL-1200 GoldWings
20.00 " L <>1.34" OD <> 45/70 Lbs/In. <> near 0.230 wire <> 50 winds
Progressive # 11-1152 is for GL-1500 GoldWings
20.50 " L <>1.35" OD <> 35/80 Lbs/In.
Things happen for reasons.
In 2004 I puirchased my already triked 97 GL1500 SE / Lehman trike, I knew this bike since purchased new in Oct '96, it was first '97 delivered in H-burg. Original owner triked it in '97. He was a Lehman installer, they rode it for years as he built others for folks.
It already had Progressive # 11-1152 as indicated by the reciepts they kept in a book of all items for it. Complete with records and a trailer!
I had it a month before I ordered a Champion EZ Steer in 6 degree flavor, got one of the last before they stopped making the 6 degree one he said. Near $900 shipped, I installed Oct '04, reused the Progressive # 11-1152 springs as all I had on hand.
Rough ride and front end sdagged. Look at spring rates above, see why? I do.
Couple years ago, tired of the beeting, being a procrastinator too, I looked arouind and found a set of springs listed for a 1200 on Ebay, I ordered them, as number sounded familiar to what I was looking for 11-1122. Got them, slipped them in in place, WOW!, it was wonderful. They fit a little loose in the bore, squeaked at first, but oh ... What a Ride they gave! Looking later on box, see they were really Progressive # 11-1112 springs, not the 11-1122 springs I thought I ordered.
The squeak went away first ride.
Speed forward, I keep eyes open on Ebay, one day picked up a set of the 11-1122 springs for a GL-1200 cheap, new in box. I get them and put on a shelf.
March 20th, we take a ride over to the Maple Festival, great trip, fun ride. That evening or the next, while cleaning the trike I decided to slip the recently aquired 11-1122 springs in place and removed the 11-1112 springs. I made up 5/8 spacers and that with the shorter 11-1122 springs held the front up near top of stroke at rest. These are the springs Progressive sells for the GL-1200 and the OD is very nearly the same as stock 1500 springs.
Took several rides since, still a comfortable ride, 10X better than those 11-1152 springs originally in it, and front set up ... but memory told me the "wrong" 11-1112 springs rode better, swallowed bumps better, and held the front up as well as the 11-1122 springs with spacers ... even without spacers.
Saturday we had a near 250 mile ride planned, we went.
Saturday night as cleaned it up from what was a dusty ride, I decided to slip the "wrong" 11-1112 springs back in. It's really easy now, can do it in 30 minutes.
Jack under front of motor and set on wooden blocks.
Remove schrader valve and drop 5" long smooth 1/4 bolt in hole to keep it all together when loosened, just loosen top clamp and bring out cap & tube extension as one unit (I have fork tubes mounted so about 3/8" of top extension protrudes above top clamp so that top of original fork tube is inside bottom ... so now the top clamp helps allign the cap & tube extension with fork tube as I stand over with speed wrench and chest board I made up). Remove springs one at a time, I wipe new springs with fork oil and insert, put back together.
Sunday, we take another 268 mile trip.
Yep. memory was right, these Progressive # 11-1112 for Kawasaki KZ1200/1300 will now remain in my GL1500's 6 degree raked front fork tubes from here on out.
I might play with fork oil weights, have a 50/50 mix of 7 and 10 wgt Belray Fork Oil in it now, about 8.5 weight, 350 CC each. 325 CC is enough though though.
The 1122s were good, and if not for a mistake I'ld be using them and not know any better ... but for a mistake in reading a number on my part and the shippers (the listing showed 11-1122, the numbers on the box so simular upon reciept that I just didn't notice, and the length looked right!). These 1112s work bumps and bridge joints and ripples and etc ... even better.
[/align]
