Throttle problem 1989 GL1500
1.3K views 5 replies 6 participants last post by  ALEX BERECZKY
#1 ·
Sorry to bring this up again but I didn't see my problem in the past throttle cable issues.
When I release the throttle the RPM will not return to 850 RPM. Most of the times it stays at over 1000 RPM unless I push closed on the throttle.
The cable are not binding. I lubed them. I checked the cruise junction box, and all looks good there.
What I did notice is the throttle cam on the carbs does not go all the way to the idol adjust screw.
I took the cables off the bracket just before the cam and it still does not go to the stop.
I think the carbs are going to have to come off and be rebuilt which i'm sure is going to be expensive.
Has anybody seen this before? I've heard of one person that took their carbs off and took the butterfly vales out. When they put them back in there was an alignment issue that may have caused the same type of problem.
#2 ·
Have you removed the grip and greased the handlebar end?
Check the idle screw adjustment inside the fuel fill compartment.
If you loosen the cable adjuster considerably and snap the throttle does it return to idle?
Remember that when you adjust (measure) the cable slack not to include the travel portion from resting position to rolled forward as this is for cruise cancel. Kinda hard to explain clearly, hope you get what i'm trying to say.
#4 ·
.....I've heard of one person that took their carbs off and took the butterfly vales out.....
No need to remove them for a normal cleaning/build. Some carb.s need them pulled to change some of the o-rings between the carb.s but not the 1500s. If you bike has never been apart this should not be your issue.
BTW: I have family in you town and visit there fairly often.
Bill
#5 ·
Before doing anything like ripping into your carbs, I'd recommend taking the "pull" cable off of the carbs. with this cable removed you'll be able to see if the problem remains or goes away.
If the trouble remains, then look at sticky trottle linkage or weak return springs on the carbs
If the trouble goes away, then one or more of your 4 cables, or the mixing box is sticky.
This symptom is pretty typical for an over tightened throttle (not enough slack), it'd be a time savings to check the adjustment on your pull cable to assure that you'v got too much slack, and then repeat your testing for return to idle.
#6 ·
Before doing anything like ripping into your carbs, I'd recommend taking the "pull" cable off of the carbs. with this cable removed you'll be able to see if the problem remains or goes away.../QUOTE]
+1... Also use that opportunity to Spray-Clean/Lube the (3/4" dia) springs that pull the throttle closed... if they're gunked-up, then the throttle won't close. Test by manually rotating the cable pulley, verifying smooth operation, and repeatable closing of the throttle.
You can do a decent job of that with the carb still installed.
Save
